03-30-2023 03:45 AM - last edited on 06-10-2024 11:00 AM by Content Cleaner
cybersecurity requirements are asking for encryption of file-system on our cRios (9054, 9068, etc). I wonder if there is something officially supported. In
Best Practices for Security on RIO Systems - part 1 , part 2 and part 3 there are many suggestions, but I haven't found anything about encrypting files and folders.
Any recommendation? Thanks in advance
Solved! Go to Solution.
03-30-2023 08:11 AM
the way to go on Linux is usually to encrypt a partition with LUKS. But I don't think that it's possible to encrypt the whole NI Linux RT system with LUKS because this would need very deep changes on the OS. Though, encryption of a new created partition or an attached USB drive should be possible.
03-31-2023 11:09 AM
Thanks for the answer. We do not need encryption of the whole NI Linux RT, just some folders. We are going to try LUKS then.
07-29-2024 06:53 AM
Did it worked after all?
08-05-2024 01:53 AM
Eventually we did not try it out. I believe it would work though
