04-28-2023 08:07 AM
I have a FlexRIO PXIe-5775 (KU060) which I need to get the full 6.4 GS/s from. In the IO Socket CLIP Details section, there is the following text:
"This CLIP exposes two 3.2 GS/s AI channels to the LabVIEW diagram. The interface for each channel is 16 samples wide, hence driven by a 200 MHz DataClk.
The converter is capable of running at 6.4 GS/s though a single channel. The input can be configured for 6.4 GS/s by enabling interleaving of AI0 and AI1."
My question is, how do I enable interleaving of AI0 and AI1 to achieve 6.4 GS/s? I have not been able to find any information on this in the documentation or discussion forums.
Solved! Go to Solution.
04-28-2023 01:52 PM
Was sent the answer to this from another source, including it here in case anyone else runs into this problem:
"C:\Program Files\National Instruments\LabVIEW 20XX\ProjectTemplates\Source\FlexRIO\NI5775\Getting Started" contains example projects for each 5775 variant, and includes "Set Interleaving.vi" which shows how to enable this feature.
