05-05-2023 05:24 PM - edited 05-05-2023 05:31 PM
I have a newbie question about some new hardware setup.
As shown below, the host computer is connected to a cDAQ chassis (cDAQ-9189) and a cRIO controller (cRIO-9047).
The cRIO has 1x NI 9870 + 7x empty slots.
The cDAQ chassis has 1x NI 9860 + 6x NI 9224 + 1x NI 9212.
None of these modules is shown in NI MAX.
DAQmx is installed.
How can I make NI MAX detect all modules in network/remote systems?
Any tip would be appreciated.
Solved! Go to Solution.
05-05-2023 08:57 PM
For cDAQ, see Modules in Ethernet cDAQ Chassis Are Not Recognized in MAX
for cRIO, see NI 987x Module's COM Ports Are Missing From NI MAX. NI-9870 is a serial module. You need to install NI-VISA and NI-Serial driver on the cRIO controller.
05-06-2023 10:52 AM
I simply clicked 'Add Device' for the cDAQ chassis and NI MAX populated all modules in it.
For the cRIO, I installed NI-Serial on the host computer and then installed bunch of drivers on the RT target.
Now I see every module in NI MAX. Thank you!
