I would like to store multiple waveforms to an SD Card using NI 9802.
I am currently generating a 0-10V triangle wave on an NI9263 Analog Output Module, Port 0. (This will eventually be routed to an antennae.) For now, I am routing the Analog Output to an NI9215 Analog Input Module, Port 0. I would like to generate the waveform on the Analog Out Module, and then record the waveform for 2 seconds at a 100kHz sample rate with the Analog In Module. I have an NI9802 SD Memory Moduel, and I would like to store the waveform to the SD Card. The end application requires multiple appended writes to the SD Card, becasue it is intended to be autonomous.
I do not have experience with the cRIO platform, so my abilities are limited.
I'm able to generate the waveform that I want, but reading and writing to the SD Card is difficult. I cannot find very much documentation or examples on how to do this. I can only write to the SD Card with Unsigned 16 bit words, in a binary format. This limits my ability to capture a high resolution waveform. Any help/suggestions is greatly appreciated!!
I have attached a screen capture of my waveform vi. My code for writing to the SD card is worthless...hopefully someone knows how to do this correctly.
(5,147 Views)
Hey Oddjob,
The LabVIEW example finder has an example for writing data to an SD card using the 9802. In LabVIEW, just go to Help > Find Examples and search for '9802' to find the 'NI 9802 Write' example project.
I hope this helps.
Ryan
Ryan P.
CLA
(5,125 Views)
