07-06-2016 02:55 AM
I want to use NI 1483 with camera Baumer HXC13, which is confugired for 8-tap 8 bit, with resolution 1280x1024. How can I change the example code to make it correct? I have already change in CL DATA TO PIXELS.vi to 8-tap 8-bits, and Unbundle by Name from Pixel 0 to Pixel 7 enlarge. But all I can see in Image Window after starting the problem is black window. What else do I wrong? I would really appreciate all the help. Thank you a lot.
07-07-2016 02:28 AM
can you post the example code?
07-07-2016 03:09 AM
Ok, I am sending labview project in Attachements.
Kind regards
07-07-2016 03:27 AM
please also post the VIs of the project.
07-07-2016 03:39 AM
Can you grab an Image correctly in NI-MAX?
07-07-2016 04:26 AM
You mean if I see camera under NI-IMAQ Devices? Actually I don't. I don't see any file from IMAQ in my Devices and Interfaces
07-07-2016 04:35 AM
But the 1483 is recognized in MAX?
07-07-2016 04:42 AM
Yes it is
07-08-2016 02:08 AM
All I get now is black image with white points. Where could be the problem? I think there is no problem with comunication with camera right now. Maybe something with resolution?
07-08-2016 02:42 AM
did you check the aperture? Take a flash light (not too bright) and light directly into the lense. Does that make a difference? The topic is pretty complex and it could be a lot of reasons why the image is black....
