08-21-2017 06:02 PM
Is there a way to connect the NI-9211 to your computer (via USB) without using a chassis?
08-22-2017 10:35 AM
Hi SonOfCabe,
You can use the 9171 single slot chassis to connect to your computer using USB:
http://www.ni.com/en-us/support/model.cdaq-9171.html
08-22-2017 01:17 PM
@rleonard3 wrote:
Hi SonOfCabe,
That's exactly what I'm trying to AVOID! I'm looking for a simple cable solution, if it is possible.
08-22-2017 01:25 PM
The 9171 will be the simplest form factor to connect your card to your computer. The 9211 doesn't have the inherit ability to connect via USB.
