02-19-2016 02:07 AM
Goodmorning,
I'm looking for a thermo-hygrometer (device which can mesure temperature and humidity) compatible with labview and if possible with a USB connector.
Did you ever heard/use a such device ? I've made some ressearch but I can't find this.
thank you by advance.
Solved! Go to Solution.
02-19-2016 01:46 PM
I've used this one in the past but it depends on your specifications.
Hope this helps
02-22-2016 01:50 AM
Thank you ! I found it an other which seems better but thank you ! ( Your Temperature range is smaller )
