02-09-2006 09:58 AM
02-09-2006 11:33 AM
12-05-2022 06:14 AM
I came across the same issue. How do you connect your Host PC and the 2 cRIOs - USB or through network?
12-05-2022 07:19 AM - edited 12-05-2022 07:20 AM
Wow, blast from the past. NI project files where never designed to support more than 1 target with the same exact code in both. Its still an issue with the version of Labview RT I'm using. There aren't any good solutions or workarounds that I know about. I'm constantly changing the IP address target and never have both connected to the project at the same time.
07-30-2024 12:15 PM
Has anyone tried the Replication and Deployment Utility?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019QTLSA2&l=en-US
Once you get the code working on cRIO, you should be able to clone the system image to as many other cRIOs as you want.
08-15-2024 08:17 AM - edited 08-15-2024 08:19 AM
I've had projects with multiple cRIO targets each with their own IP address, both same and different models, quite a few times. The one difficulty is that if you have a target connected and running it will lock all VIs and you can't make any changes to them if they are referenced in another target.
Other than that I haven't really run into serious difficulties with that. I have currently a project in LabVIEW 2018 (because it uses the old obsolete VxWorks cRIOs) and one in 2020 that use this. I do use FPGA Open with a configured bitfile instead of a direct main VI referenced. This decouples some dependencies but requires you to be a bit diligent about what actual bitfile you reference.
