Voltage acquisition with NI 9206
I'm using a NI 9206 module with a CRIO 9081 to get 14 voltage acquisition from 0.4V to 5.8V using the RSE mode.
Then i connect the 14 pin to the module from the input AI0 to AI 15. When i connect the 12 first pin, i get the good acquisition but when i connect the last two pin, the first two voltage (pin AI0 and AI8) increas from 0.4V, and this is what i don't understand.
I've tried to remove the two first input but then, the two next voltage increase as well from 0.4V.
That's why i wonder if i've forgot something, why the first input increase and if someone have already mett something similar.
Tahnk you 🙂
(3,578 Views)
Accepted by vincentlg
Sounds like you are seeing a form of ghosting to me.
GCentral
(3,576 Views)
Yes, finally it was probably a goshting problem, then i increase the interchannel delay and it seems to work well now.
Thank you for your help !
(3,541 Views)
