cRIO 9063 in SAFE MODE and MAX Network Adapter settings are Read-ONLY
Hello:
- A customer got creative and decided to RESET the cRIO-9063 causing it to RE-SET IP Address to 169.254.54.109 and  to boot in SAFE-MODE only. --All the time.
- To recover the cRIO I installed latest NI MAX and cRIO drivers
- NI MAX was able to find the cRIO 9063 controller online.  However, the Network adapter TAB showed info in Read-Only mode
- I wanted to Re-SET IP Address to 192.168.1.99 and to remove safe mode. But this was not possible because MAX only shows info in READ-ONLY mode.
Is there any way that I can restore IP-Address and configure the controller to boot in Normal Mode?
Thanks for any advice.
Anthony
Message 1 of 1
(764 Views)
