cRIO TCP/IP Re-establish communication
Hello everyone. I have a cRIO communicating with my PC through the TCP/IP protocol to send and receive some data. I want the connection (through the ethernet cable) to be re-established, in case the connection is lost (for example internet connection is lost or the ethernet cable is off). It works by default for a specific amount of time (a few seconds), but there seem to be a problem when the connection is off for a long time (a minute or more). Any ideas?
(2,898 Views)
Accepted by gvagenas
Use a State Machine.  Start in the Connect state and repeat until a connection is made.  Then progress to the Run state.  If an error is detected, go to the Disconnect state and then back to the Connect state.
GCentral
(2,866 Views)
Thank you a lot for your quick reply. I have two VIs, one under My Computer and one under my device. Should I implement it on both VIs? Thank you.
(2,863 Views)
That is what I do.
GCentral
(2,851 Views)
