08-07-2017 04:13 PM
Per previous NI support I deleted everything and started from scratch, for the USB-7856R board:
-Installed Labview 2016 32bit on Win 7-64
-Installed the Real Time module for 2016
-Installed the FPGA module for 2016
-Installed the Xilinx ISE and Vivado tools (not mentioned in support but required for this board)
-Installed the compact RIO drivers (1600)
-Installed the R-series drivers (1600)
(I did some installing and reinstalling out of order of the last few items while troubleshooting. The last thing I did was uninstall the R-series driver, reboot, then re-install)
Any help would be appreciated. I already have code from another machine but need to edit with the simulation at my desktop.
thanks
08-08-2017 04:10 PM
Hey Matt,
Can you include a screenshot of where the issue is happening? E.g. when you try to add the target to your project, when you right click on it to configure mode, etc.
08-08-2017 04:25 PM
Hi Andrew thanks for you help.
I did manage to get a simulation but by accident. I right-clicked the existing hardware in my code and selected simulation under execution mode. But that doesn't match the instructions I found on the web that this thread is about.
Here is a shot of me not finding my target device in the menu.
08-09-2017 03:52 PM
Hi Matt,
One thing is that you'll need to right click on My Computer instead of the project. You won't be able to add an R Series card to the top-level Project part of the hierarchy.
Cheers,
Ryan C.
08-15-2017 01:24 PM
Hey, that works too, thanks!
