How can i convert the input reading of my CRio (connected to an analog tachometer) that is a ''double'' into a waveform(DBL) ? i need this conversion to use the analog tacho processing VI to read the velocity profile.
Build Waveform. You will need to supply a dt (sample rate in seconds/sample). You already have the Y (your array of doubles).
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
