SAPHIR - Toolkits Discussions
Modbus TCP I/P to Modbus RTU
Dear All,
We currently have project which needed to communicate to DCS system.
Connection in our internal system are using Modbus TCP I/P, but connection at DCS system is Modbus RTU RS485.
Please kindly to sent me a reference about how to connect this system
appreciated your advice and input
thx
radiks
(5,308 Views)
Hello radiks,
To implement Modbus over TCP you need to have the device you want to communicat with on the TCP/IP network and then you can use our toolkit http://www.saphir.fr/en/produits/gmodbus-over-tcp-6.html to connect it with a LabVIEW application.
Concerning ModBus over a serila link, you need to use the right cable and the right RS485 device (PCIcard or USB/serial converter) in order to connect your device. THis is definetly the most difficult part of the job because pin connector assignment could be different from the different manufacturer. You need to refer to the documentation to check this. On the LabVIEW side you can use this toolkit http://www.saphir.fr/en/produits/gmodbus-over-serial-line-8.html
If you want to continue to use ModBus TCP you can also glance at a modbus gateway. This will allow you to adress your serial device throug a TCP network.
Hope this will help you to success in your project.
Have a great day.
Olivier
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn |
Stop writing your LabVIEW code documentation, use Antidoc!
(4,060 Views)
