VIBox Quick Drop toolkit is a set of NI LabVIEW Quick Drop plugins that will help you boost your productivity.
This toolkit includes SAPHIR made plugins and also free plugins developped by the community.
Want to learn more about Quick Drop? Follow the links:
http://www.ni.com/white-paper/7423/en
https://decibel.ni.com/content/groups/quick-drop-enthusiasts
VIBox Quick Drop toolkit will provide you the following SAPHIR Quick Drop shortcuts. You may also find a documentation of these plugins in LabVIEW menu Help/SAPHIR/Documentation/ViBox - Quick Drop help.
Shortcut | Name | Comment |
Ctrl(-shift)-E | Set Connector PanE | Connect controls to the connector pane according to their front panel position, and a smart readable scheme. Can handle a VI with up to 4 inputs and 4 outputs. Options :
Ctrl+K | Connect Tunnels | Connect tunnels in a multiple frame case structure |
Ctrl(-shift)-M | Add coMMent | Add a pre-formatted comment on your VI. The formatting instructions are located on <LabVIEW>\resource\dialog\QuickDrop\plugins directory, Comment*Text.txt files Options :
Text file options :
Ctrl(-shift)-N | CoNtrol to iNdicator | Switch between controls, indicators and constants. Options :
Ctrl(-shift)-S | Remove Structure | Options :
Ctrl(-shift)-Y | Disable code | Put a Diagram Disable Structure on the selected part of code Options :
Ctrl-Z | Resize structure | Resize the selected structure or the block diagram if selection is empty |
VIBox Quick Drop toolkit will also provide you the following community plugins, for easiest installation. You can find more informations on these plugins on https://decibel.ni.com/content/groups/quick-drop-enthusiasts
Ctrl(-shift)-A | Array to constant | Change a constant to an array and vice versa |
Ctrl(-shift)-B | Selective wire cleanup | |
Ctrl(-shift)-C | Clone control | Duplicate selected controls "in" to indicators "out" and vice versa |
Ctrl-G | AliGn & Connect | Wire selected VIs Shift : also perform a code clean up |
Ctrl-L | ALign controls to pane pattern | Align controls/indicators according to their connector pane position |
Ctrl-O | Reset to Origin | Move the block diagram or the front panel to the origin |
Ctrl(-shift)-U | Fetch snippet | Transform an url towards a snippet to code |
Ctrl(-shift)-V | Better moVe | Move selected code to remove wire bend. Use arrow to set direction |
Ctrl(-shift)-W | Insert or replace | |
Ctrl-X | Show radiX | |
Ctrl-/ | Rewire error case struct | |
Ctrl-$ | Alphabetize case structure |
Many special thanks to every Quick drop enthusiasts community contributors who allowed us to include and distribute their great job!
Have just put the QD plugins through a simple test, and they are just great. 🙂
These are more or less going to be an essential part of my QD toolbox.
Have just 2 small comments:
No shift: The selected code is copied onto disabled case
Keep up the good work.
If only I could use these in LabVIEW 2011 (where I do most of my developement)...
Hi Michael,
Thanks for your comments, they encourage us to do more ! 😉
- Concerning the use of Set Connector Pane : if one or more connectors are already connected to the pane (at the wrong place for example), and you want to clear everything, you can use the shift option. This is working here with simple examples, but if you have a not working example, you can send us it so that we fix it
- Concerning DisableCode : OK I just fix the comment...
If we have some time available, we may publish some video to show how to use our QD plugins...
Hi crossrulz,
The next step for us will be to convert them to previous versions of LV.
But if you own a license of LV2012, I think you just have to save for previous version the 6 VIs named SAPHIR_* in the resource\dialog\QuickDrop\plugins folder of LV2012, and place them in the same folder of LV2011.
Concerning others versions of LV (2009 and 2010), I'm not sure it will be so easy ...
Just updated our tool to be used with LabVIEW 2010 and later.
Enjoy ! 😉
Hello Saphir people, I just played around with your new QD shortcuts (in LV2011SP1) and like some very much. I'm not the most experienced QD user yet, only familiar to the standard 5-6 QD commands.
Comments to your shortcuts:
- I think it would help to have the explanation of a Shortcut also in the "Selected Plugin Description", after installing them i have there a wrong description for all SAPHIR shortcuts, the one from the "Replace" shortcut.
- The Ctrl-Y to disable code would be nice. But when i try it, it duplicates code and in the disabled case the code doesn't keep its position, jumps to the upper left corner and wires going to the boarders are removed. Is this what you want?
- Is the Ctrl-G something Darren makes with his Ctrl+W? Or was he inspired by yours?
Hi David,
In reply to your comments :
Thanks for your feedbacks!
Just updated version v1.2.1 which includes some community plugins
Great job Saphir can i suggest to creat and add Quick drop plugin who list all shortcut of your plugins. it's not really easy to remember all of them and what they do. Perhapse "Crtl- H" for control help... Regards Eric Bobillier
