Signal Conditioning
How to scale a 4-20mA signal
I've figured out how to realise the right output, I've programmed the correct numbers to convert the signal to reasonable results. Thanks for all the replies, consider this topic closed! 🙂
Message 11 of 12
(3,152 Views)
Accepted by topic author Warrian
Hello Warrian,
Thanks for letting us know!
Can you mark it as resolved?
This way other users can easily find this post if they have a similar question 🙂
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 12 of 12
(3,144 Views)
