07-13-2013 09:58 AM
Hello I am using a SCXI 1000 chase with two SCXI 1125 cards. My question is how can I configure a software filter that works like the one implemented in the SCXI 1125 card. More exactly i what to build a 4 Hz cuttoff lowpass filter. Thank you.
07-15-2013 05:52 PM
Hi Padeanu.L,
What is keeping you from simply configuring the Voltage task to use the built-in 4Hz filter (shown in your screenshot)? Are you trying to implement this filter using lower-level VIs, or is there other hardware that you want to add a filter to?
07-16-2013 08:24 AM
I am using another acquisition card that does not have this option!
07-17-2013 11:20 PM
Which module are you using?
I suppose you could always just run your signal through the Filter express VI (in the Express » Signal Analysis palette) or one of the VIs on the Signal Processing » Filters palette.
