07-23-2012 04:33 PM
I am designing a test fixture for a cable assembly. It will need to connect to bare 20G solid wires, and handle up to 500VDC, low current.
I would like to stay away from screw terminals. In the past, I have used what look like stereo speaker push-buttons.
Anyone have any better suggestions?
07-23-2012 08:49 PM
I think push connectors might be the best. Look for high quality so they do not wear out. The voltage rating can be extended if need be by mounting them on a polycarbonate plate rather than metal.
Make sure it has a good interlock and some bleed resistors at both ends of the cables.
Lynn
07-24-2012 01:48 AM
Usually push connectors for bare wires are designed for less or up to 200 circles ....
Depending on the number of test performed, mounting time, ... I would ask the push button manufacturers for test fixture connectors . Take the linecard of some distributors (digikey, RS ... ) to find them.
Might not be the cheapest solution on the first run, but for daily use good connectors are always worth the money.
