Signal Conditioning
Strain Gauge SCXI 1122 and SCXI 1322
Hello everyone,
at the moment I am trying to get started with strain gauges. Due to this, I bonded a strain gauge on a specimen which was included in the strain gauge starter kit of my strain gauge vendor. I thoroughly followed the video instructions of the strain gauge vendor to bond the strain gauge. To read the strain I am using the combination: PCI 6220 -> SCXI 1000 Chassis -> SCXI 1122 -> SCXI 1322 -> LabView Signal Express 2011 Version 5.0.0 (included in the hardware as Evaluation Version). In Signal Express I added a New Step: Strain Measurement. For this test I use one active strain gauge(bonded on the specimen) with a 120 Ohm dummy completion resistor (the dummy resistor is no strain gauge, it is just a normal completion resistor for testing purpose). Due to this, the bridge configuration in Signal Express is Quarter Bridge II. I connected the strain gauge quarter bridge to the terminal block (SCXI 1322) like shown in Figure 3-7. Also I entered the other informations like gage factor, gage resistance etc.... The sample rate is set to 10 Hz, and the I am using the default low pass filter of 4kHz (it is default in Signal Express). When I run the project, I get values for the strain about 11.xyz micro (E-6). When I bend the specimen (see attachment for picture) down(tension) with my hands the strain is increasing but realy less (0.x micros up to max. 1.0 micro), when I bend into the other direction (compression) the strain is decreasing (again: 0.x micros up to max. 1.0 micro). But sometimes Signal Express is just measuring a non changing value of -1.54xxyy milli, it does not change, even when I bend the specimen with my hand. To get rid off this I have to reset the SCXI 1000 chassis electrically to get the micro strain values. This 'phenomen' happens a lot of times then, when I try to calibrate the system via Signal Express in the 'Device' tab of Configuration tab. Do I have to make some other confiugrations ? What could be my mistake depended on the software side of this test measurement ? I appreciate every hint ! I apologize my bad english and the bad quality of the pictures in the attachment.
(6,306 Views)
Hell opcode_torule,
maybe someone could help you, if you provide other forum users the configuration of the Measurment & Automation Explorer. For this purpose, see this webpage:
Documenting Measurement & Automation Explorer (MAX) Configuration Information - National Instruments
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4
If you choose Technical Support, you will get the report with the most information. Maybe it is a problem connected to the configuration of the SCXI-1000 chassis.
Regards, Stephan
(6,272 Views)
Hello Stephan D,
thank you for your answer and your suggestion. I will have a look at it.
I wish you a nice weekend and a good evening.
best regards,
(6,269 Views)
now I made a quarter bridge of type II (active gauge and a dummy gauge). I bond the strain gauges on a steel beam wich has a length of  940mm and the the strain gauges are placed with a distance about 45mm of the fixed point. In Signal Express I get a strain of 13micros (the beam is bend due to his own mass). To get a reference value I calculated the strain with a FEM programm and I get at the same position a strain about 170micros... there is factor 10....something is not normal. Can anyone help me ?
I just put the technical report in the attachment as a ZIP archive.
best regards,
opcode_torule
(6,259 Views)
Hi opcode_torule,
thanks for the report. For me, it looks ok. Unfortunately, i don't use the SCXI-Hardware and i can't help you very much.
Maybe you sould try to contact the technical support of National Instruments, because they have more knowledge about SCXI than me.
Stephan
(6,254 Views)
Hello Stephan D,
thank you for your reply. How I can contact the technical support ? Telephone ? Do they maybe have a german speaking support ? :-).
Uff... I am getting crazy right now with this problem.
thank you !
(6,252 Views)
The NI Support is available in almost every language, even in german for customer from germany, switzerland and austria.
The information for germany can found here:
Kontakt - Germany - National Instruments - National Instruments
https://sine.ni.com/apps/utf8/nicc.call_me?p_country=Germany&p_lang_id=D&p_form_id=31
(6,250 Views)
