Signal Conditioning
USB-6212
we have the analog digital controller USB-6212 and i would like to know if it has the opportunity to connect 2x 5V TTL signals.
Thanks for any help!
Julius
(2,792 Views)
What do want to measure?
the 6212 can measure analog voltages, but if you say TTL  maybe you want to count or measure timings?
All this can be done with the 6212..
If you open MAX and create a measuring task with your 6212 , the assistant should even give you a coarse connection diagram.
Greetings from Germany
Henrik
LV since v3.1
(2,787 Views)
I want to measure the torsion angle from a torque sensor.
the output signal form this is 2x 5V TTL and I want to know if it’s compatible
(2,784 Views)
Accepted by Julsbng
Ah, you use an incremental angle sensor?
According to the spec the 6212 aupports incremental encoder 🙂
Have you tried to create a task in MAX ?
Didn't it show up a connection diagram?
Henrik
LV since v3.1
(2,738 Views)
