10-11-2015 07:03 AM
I'm a newbie when it comes to NI and DAQ. I've purchased a NI USB 6211 and connected a resolver with 400 hz to ai1 and ai2 (RSE) (sine and cosine signals). I also have the reference signal from the power supply connected to ai3 (differential). Voltage deviders give me a +/- 2.5 Volts input signal from all sources.
The problem is that the signal shifts to the right. It evenly shifts for all signals.
I'm now wondering whether it's possible to synch the input signal so that it doesn't shift? or do I have to programmatically solve this issue ? I'm programming in C with the standard DAQmx drivers (v15.1). But I've seen the same issue with Labview and Measurement Studio.
Thanks in advance for any suggestions.
Kind Regards,
Gerhard
10-11-2015 08:23 AM
I guess I just found the answer to my question here:
http://forums.ni.com/t5/LabVIEW/DAQ-Assistant-can-t-lock-the-signals/m-p/1332484#M542285
I guess I need to ask in the C++ forum section for an example of a software lock.
Gerhard
