08-31-2017 08:00 AM
Hello all,
I have a QuickSyn Lite Synthesizer here FSL-E020
So, I would like to know if we have any LabVIEW Driver available from NI for this Module.
Although I have been provided with a Soft Front Panel to operate the module, I would like to make it work programmatically, eg: setting the target frequecny for the module using labview program.
Any help would be appreciated.
Rahul
09-04-2017 07:30 AM
Hi there,
there should be a driver available over VI Package Manager. Try to find it there. I found this manual:
QuickSyn Driver and LabVIEW API Installation 1. Go to Phase Matrix’s website to download the required driver files: http://www.phasematrix.com/pages/Synthesizers.html Download the following QuickSyn files: Software: USB Drivers USB Front Panel GUI Installation File Data Sheet Quick-loading version or Hi-res version (recommend Hi-res version) User's Manual; QuickStart Guide Quick-loading version or Hi-res version of the User Manual. (recommend Hi-res version) 2. To install the LabVIEW API for PMI QuickSyn, there are a number of software tools that need to be installed. The first tool is called the VI Package Manager. This can be downloaded from the following link: http://jki.net/vipm Download the free community edition. Install it on the computer that will be used to program the PMI QuickSyn. Once the JKI VI Package Manager has been installed, it is fairly easy to use. Open the package manager directly, it will show a list of anything that is currently installed on your computer that it is supposed to keep track of. The first time the VI Package Manager is used, it will prompt you to test its connection to LabVIEW. Go ahead and follow through with it. The easiest way to install one of the package files, is to click on the file in Windows and let Windows start the Package Manager. This action will start up an installation window. The title will be the package to install. In the upper left hand corner, a part in the upper left will indicate which version of LabVIEW it is currently targeting. You’ll have the option to select which one you want if you have multiple versions installed. Below the LabVIEW version should be button that you click on that starts the installation process. Click on it and follow the prompts to install the package. 3. Download and install the LabVIEW PMI QuickSyn programming API. Currently this version only supports the basic QuickSyn functions so far. No List mode etc. But does support enabling the AM. FM, and Pulse modes. Download it from here: ftp://ftp.ni.com/support/rf_segment/niRF/nirf_-_niquicksyn/ niRF - QuickSyn Single Install.vipc This will install two components: nirf_-_niquicksyn v0.2.2.5 ni_tool_esf v2.4.0.25
I hope this helps
Heinz
09-05-2017
03:04 AM
- last edited on
11-12-2024
11:39 AM
by
Content Cleaner
Hi Heinz,
Thank you for your reply.
Actually, I found a Synthesizer programming manual Communications Specs for Programming on their website. It conatins Control Commands in Hex strings to perform different operations.
Example:
Set Output Frequency to 9.876543210 GHz
