Signal Generators
max current PFI as output
I have PXI 5441 generator, but I can't find max current the PFI can drive as output in it's specification.
PXI-5441 Specifications - NI
Actor Framework
(1,767 Views)
It is available indirectly as VOH, VOL values at load - you can calculate current from voltage and resistance (do consider the 50ohm output impedance of PFI)
Similarly, it is available for the other connectors too,
Santhosh
Soliton Technologies
(1,753 Views)
