SignalExpress
Data view crash
I use signalexpress to record temperature data.
I can see the data value in step setup window.
However, when I want to read the data in data view, it can't show up and then shut down automatically.
I had been face the situation before and solved it by using full license.
But now I have no idea how to solve it, please help me!
(3,568 Views)
Accepted by CH7777
check this link , maybe Your application requires newer software.
If not, You can share Your code, maybe problem is there.
(3,527 Views)
Hi IDASYAN,
From the link, I found maybe the driver is too new to make signalexpress 2015 crash.
I uninstalled original DAQmx and installed DAQmx 14.5 and signalexpress 2015.
And it worked! Thanks a lot!
P.S The link below is DAQmx 14.5 from NI.
https://www.ni.com/zh-tw/support/downloads/drivers/download/unpackaged.ni-daqmx.288233.html
(3,505 Views)
