Sound and Vibration
Measurement of hydrophone signals using PXIe-4464
Hi all
I am searching a data acquisition card with built-in pre-amplifiers which i can interface directly with hydrophones to measure voltages. One option i came across is PXIe-4464 4-channel Sound & Vibration Card.
My query is that can i directly measure very low voltage output signals (perhaps in u-volts) of hydrophones using PXIe-4464 built-in preamplifiers (i.e. without any external preamplifiers b/w PXIe-4464 & hydrophones)?
(3,015 Views)
Hi all
Any suggestions please?
Thanks & Regards
(2,916 Views)
It seems feasible with the 30dB range and the 119dB dynamic range, you should be able to detect uV signals. The choice depends on the absolute accuracy of the measurement required.
Side note, since you are talking about uV signals, every connector could introduce thermocouple effect which are few tens of uV depending on the material.
Santhosh
Soliton Technologies
(2,903 Views)
