Switch Hardware and Software
C-series module for functional safety NI-9351
Hello, everyone,
my group bought a  C-series module for functional safety NI-9351 for experiment set-up.
but after reading the Manual, I still not understand how it works and what does it work for. I think it might be used for an emergence stop?
Does anyone know this Module?
Thank you very much.
(4,330 Views)
The module contains built-in diagnostics that can monitor the status of the hardware and the integrity of the connections.
It can be used to control critical safety functions in manufacturing assembly and test cells, large physical tests, condition monitoring applications, and process monitoring and control.
Probably you can refer to these links below.
Datasheet
https://www.ni.com/pdf/manuals/377936a_02.pdf
Product Details
https://www.ni.com/en-my/shop/hardware/products/c-series-functional-safety-module.html
Product Flyer
https://www.ni.com/pdf/product-flyers/c-series-functional-safety-module.pdf
To program the module, kindly use "Functional Safety Editor" software.
Functional Safety Editor Overview
https://www.ni.com/en-my/innovations/videos/17/functional-safety-editor-overview.html
Functional Safety Editor Download
https://www.ni.com/en-my/support/downloads/drivers/download.functional-safety-editor.html#326204
Hopefully it helps.
Thanks.
(4,295 Views)
Thank you for your help.
do you know if this module can be connected to the laser machine or thermocouple so that it can monitor the temperature conditions?
thanks for your help.
Best regards
(4,286 Views)
Accepted by Zxc123456.
9351 has 4 AI channels capable of measuring 0-20mA current loop, if you got a temperature transmitter that could output 0-20mA, then yes, you can implement the temperature monitor.
Santhosh
Soliton Technologies
(4,277 Views)
There is a self-contained safety logic solver in the module.
sensor -> logic solver -> final element
https://www.ni.com/pdf/manuals/377936c.pdf
https://www.ni.com/en-my/innovations/white-papers/17/functional-safety-for-compactrio.html
https://www.ni.com/en-my/innovations/white-papers/17/functional-safety-overview.html
So you can connect a sensor to the module and used it for the temperature monitoring.
Thanks.
(4,266 Views)
