We are trying to use our PXI-2530 with a TB-2630 to be used as a ground/open switch. Currently, using the MAX software the self-test was completed successfully but when we use the NI-Switch Soft Front Panel. The relays are not displayed and are unable to be enabled/disabled. When a reset is processed, the machine has a problem and the time allocated to preform this operation is exceeded. The status code is: -200221. Any help would be welcomed! Thank you!
