04-23-2019 02:22 AM
After applying customization, the program slows too much. Do you know why? I've checked my png pictures what I used. Max 18 kb.
Thanks your helping and advice
04-23-2019 03:43 AM
would you happen to have a bit in-depth information, like:
Thanks in advance.#
Falk
04-23-2019 06:23 AM
What kind of control were you customizing (also, what palette were you using)? It would be easier to find out the reason if we could see a screenshot.
Thanks in advance,
Mariam
04-23-2019 06:30 AM
I've customized everything. Graph, button, tab, numeric control. I made changes on a working vi. Although this Vi works fluently, it doesn't work fluently anymore.
I can't post the code. At first vi is working fluently. As time goes by slowing down.
Could it be related to being a 32 bit? DSC module was used. Labview have to be 32 bit for DSC module.
04-23-2019 06:36 AM - edited 04-23-2019 06:38 AM
Do you have any decorations in the vi? Sometimes they are affecting the vi's speed.
04-23-2019 06:59 AM
I don't have any decorations
04-23-2019 09:08 AM
I had similar problem.
I customized a button to be translucent.
Worked fine on Windows 7 LabVIEW 2017.
But caused a big delay on Windows 10.
