01-13-2016 05:05 AM
We are making a custom string control with a gradient frame and a transparent text (much like the military String.ctl). Everything works almost as expected but I could not find a way to change the background color of the text while it is in "edit mode", that is, text can be entered. For example the mentioned String.ctl shows a solid black box in edit mode and a transparent background in display mode.
Display Mode Example:
Edit Mode Example:
01-13-2016 08:12 AM
I hope it will help you, if not then please share your vi for more information.
01-13-2016 08:26 AM
Unfornutaly I cannot open you link (Access denied oder "Sie sind nicht berechtigt" in German)
Please find attached an example: The string control has a image as background. The text component is transparent so that the frame background shines through. But as soon as the user enters a text, a blank white rectangle is displayed. I want to change the color similar to the real background.
01-13-2016 08:40 AM
Can you please save this string.clt as previous Version 14.0 ?
01-13-2016 08:50 AM
Of course.Thank you for your help.
