09-10-2010 02:05 PM
If you watch the NI Week Web UI Keynote talk at http://www.youtube.com/watch?v=7dWrc-R23zk; at 3min8sec they mention that the wind-vanes shown are rotating images (and obviously have some transparency).... "Images we've applied a rotation animation to"
This looks VERY slick, but I can't figure out how this would be implemented.
How was this implemented? I've seen various discussions on this when googling the problem, but no good solutions.
09-10-2010 02:10 PM
Web UI Builder is implemented on Microsoft Silverlight technology.
09-10-2010 02:11 PM
This was done in the LabVIEW WebUI builder, which is a different product than standard LabVIEW and is not quite released yet. However seeing as they mentioned it at NI week means it must be coming along soon :-D.
I don't think this is possible in standard LabVIEW, but maybe others on here have other ideas.
09-10-2010 02:12 PM
Darn, you beat me to it by just a few seconds...
09-10-2010 02:35 PM
LabVIEW does not currently have image rotation capabilties (although I suppose you could probably write the image transformation algorithm and render it in a picture control).
LabVIEW does, however, support image transparency. If you import images to the clipboard via the Edit menu (Import Picture to Clipboard) and browse to a file that contains transparency (e.g. a PNG with an alpha channel), the transparency information will be preserved when you paste into a VI. (Note that copying and pasting an image through the system clipboard will not preserve the transparency information in LabVIEW).
09-10-2010 02:46 PM
Dragging a PNG file onto a front panel (or block diagram) as a decoration also preserves transparency. I find this easier than going the Edit >> Import Picture to Clipboard... route.
09-10-2010 03:26 PM
09-13-2010 11:25 AM
Recreating the Web UI Builder demo in LabVIEW is fairly easy. I've posted an example with a quick write up here - http://decibel.ni.com/content/groups/ui/blog/2010/09/13/windmill-ui-example
09-13-2010 11:31 AM
Thanks for the details, Norm. I gather this is how it's done, which is what I was looking for. Unfortunately though, I don't really like the answer as it is fairly clumsy with all the work required with rotations in powerpoint.
Maybe I should write a VI to make it happen easier.
Thanks.
