10-24-2012 04:06 AM
Hi Attique!
I assume this is the same issue you described in a different thread:
http://forums.ni.com/t5/LabVIEW/Urgent-Help-Required/m-p/2186408/highlight/false#M701770
Let's continue there!
Kind regards:
Andrew Valko
10-24-2012 01:22 PM
Hello Andrew,
Yes this is the same problem discussed in the other thread. We will continue there...
Attique Ur Rehman
05-15-2014 10:36 PM - edited 05-15-2014 10:41 PM
I also try to configure MIMO 2x2 system with 4 USRP 2920. I set IQ rate 200kS/sec but I have error mesages in Tx: niUSRP Write Tx Data (2D CDB).vi<ERR>Packet had timestamp that was late (or too early), and at Rx : niUSRP Fetch Rx Data (2D CDB).vi<ERR>A stream command was issued in the past.. Can you help me to solve this error messages??
In my MIMO 2x2 system, I don't use external clock. I use internal in Clock Source and Frequency Source. Is it wrong?
Hendy
05-15-2014 10:42 PM
08-11-2015 09:03 AM - edited 08-11-2015 09:05 AM
Hello Mr Erik
I already implement 2x2 MIMO OFDM using USRP. I want to measure throughput of this system but I don't know how I measure it. Can you help me to solve this problem. Thanks a lot.
Hendy
08-21-2015 01:08 AM - edited 08-21-2015 01:09 AM
🙂 please read the other forum post... And ask/post there, so we will keep this issue compact
11-05-2020 03:00 AM
I am new to the SDR field. Currently, I am developing a simple USRP Tx & Rx demo. When I increase the IQ Rate to 10M, I am receiving underflow error. What is the maximum IQ Rate we can use?
Thanks in advance!
BR
Shree
