USRP Software Radio
LoRa Chirp Spread sprectrum and USRP
I'm using a USRP 2920, and I would like to get the chirp spread spectrum of a LoRa Emitter (868MHz).
I have been looking for the examples with the USRP toolkit, but i didn't find one wich could get the sprectrum.
See the attached image, to understand what I need ....
PS : with the VI "niUSRP EX Spectral Monitoring (History).vi" I can get the sprectrum (Amplitude vs frequency), but what I need is frequency vs time
Thanks !
David
(2,684 Views)
Hi David,
To measure the frequency vs time spectrum, you can use the STFT function in LabVIEW.
You can search the function on block diagram:
Signal processing --> Spectral --> STFT spectograms.vi
Also, you can find out how to use it from some LabVIEW examples. Please try to search examples by STFT keywords on NI Example Finder.
Thanks.
(2,667 Views)
Hi Chan82,
Thanks for your answer ! I have found an example with STFT (STFT spectrogram demo.vi), but now the difficulty will be to get datas from the USRP, and to use this function so I could see the specific chirp modulation ....
David
(2,655 Views)
Is it possible to interface lora using LabVIEW?
(374 Views)
