USRP Software Radio
RF interference at central frequency (NOT LO leak)
When receivig signals with our NI USRP 2920 (LV 2013, NI USRP driver 1.3), we are always observing unwanted signal peaks on the
central frequency, whatever the central frequency.
I doubt there is much power in these interferences but since we are trying to capture weak and narrowband signals, that
may be an issue.
Any idea of what these could be ? Certainly not LO leakage since the LO is shifed away. I included some snapshots
for f_c of 300 and 1500 MHz and a picture of the setup (not that for our experiments, the RF stage of the generator
is off unlike what is shown on the picture but even without any signal source, the noise peaks are there).
Laurent
(4,976 Views)
Your signals look great. That's great SFDR. Those extra harmonic peaks are very low, below -90dB. You will often see a small peak at the Center due to digital quantization noise but with no signal attached the -70dB number looks realistic.
(4,966 Views)
Hi Erik,
OK. Thanks for the clarification !
Best wishes
Laurent
(4,964 Views)
