USRP Software Radio
Using USRP 2954R with ethernet
Hi everybody,
i-m working with a USRP 2954R with PXI cable with LabVIEW 2018 32bit; i'm working both with LabVIEW and LabVIEW FPGA, and i have some questions:
  1. If i work in software domain, how could i use the ethernet link (i already have the SFP adapter for the ethernet connection) to launch a template? In detail, i want to use a simple template, like the Simple Streaming, with low and high sample rate, using ethernet for launch the acquisition and plot the data. I've already connected the device by ethernet but i can only ping the device;
  2. If i modify the FPGA VI, and i compile it in PXI connection, can i use the modified template in ethernet connection?
Thanks for the answers!
AP
(2,132 Views)
Hi everybody,
i'm working with a USRP 2954R with PXI cable with LabVIEW 2018 32bit; i'm working both with LabVIEW and LabVIEW FPGA, and i have some questions for you:
  2. If i modify the FPGA VI, and i compile it in PXI connection, can i use the modified template in ethernet connection, having the bitstream file?
AP
(2,009 Views)
