USRP Software Radio
chirp signal generation
I am trying to generate chirp signal and receiving it using USRP(2932) , the transmit port (TX1) of the USRP is connected to the receiving port (RX2) of the same USRP through RF cable , there is a problem that the receiving signal is not chirp signal
the transmitting signal parameters and the receiving signal are attached belowq1.png
(2,522 Views)
Hello
I am trying to send the same thing.
I wanted to ask if you found a way to do and if you did i hope you can help me with that.
(2,118 Views)
It seems receiver signal has saturated. Did you connect TX and RX directly with cable? you need to use attenuator if you want connect TX and RX directly.
(2,024 Views)
i am jay i am currently working on sdr based FMCW radar as far as i know i need to transmit chirp signal from usrp kit i did not find the block digram of labview where i can transmit the signal . if u have the labview file of fmcw radar sdr based would you please share with me.
(1,384 Views)
