USRP Software Radio
receive GSM signals using USRP 2920
Can you tell me, please, where I can find this example?
Thank you!!
Message 11 of 25
(5,458 Views)
Which examples ???
Message 12 of 25
(5,448 Views)
This one with the cognitive radio with GSM signals.I'm using USRP 2932 and I want to try this example if you can send it to me.
Thank you!
Message 13 of 25
(5,436 Views)
unfortunately  i didn't reach any thing related to measure the power in gsm band
but if you are working in making a cognitive radio in gsm band "same project as mine" we could work together.
Message 14 of 25
(5,419 Views)
hello, i am also working on cognitive radio in 2.4 GHz band..using energy detection method. i am facing a problem with a threshold.how to set a threshold? how is it calculated?transmission and reception is taking place accurately and if some frequency channel is vacant then how can the secondary user be transferred to that channel from other frequency channel?
Message 15 of 25
(5,298 Views)
Hello ketaki2511,
Are you using the Cognitive Radio Library (linked below)? It appears that there is a function in the CR Library that does this calculation.
https://decibel.ni.com/content/docs/DOC-29494
Applications/Systems/Test
National Instruments | AWR Group
Message 16 of 25
(5,287 Views)
hello sir, thank you so much..but i could not find any content on the link..i guess its been deleted. sir, i have already decided the threshold but if some noise comes then at time signal power can go below thresold and we might think that signal is not present but actually it is present..so at that time i have to set lower and upper threshold..i dont know how to set it ..i mean how to code for it..do you know some other parameters which can decide whether chnnel is vacant or not..signal power is one parameter..do you know others.
Message 17 of 25
(5,281 Views)
I apologize for the broken links. I have attached the library I was speaking of. Also if you go to this link https://decibel.ni.com/content/docs/DOC-29494 you may find useful information as it is NI's USRP group forum. The Cognitive Radio Library can be found there.
I do not know of any of any other channel estimation schemes other than spectral power. I was under the impression that when implementing channel estimation upper and lower boundary limits were inherently necessary for logic decisions.
Message 18 of 25
(5,277 Views)
can u tell me how reliable is the energy detection method? what are its drawbacks?
Message 19 of 25
(5,257 Views)
Hello , First i want to tell you that i had made a proj similar to you the last year i've achived all the 4 stages of cog. radio "sensing , sharing , Hopping, Evacuating " so if you wants any help let me know my facebook account is mohamed hantera .
in the other hand there are alot of drawbacks in energy detection here are the most common two
1-False alarm
2-Miss detection
for any other info let me know
Message 20 of 25
(5,245 Views)
