06-29-2016 03:45 AM
Hi, there is something I am not sure. Could you help me?
If I run the execution of UHD, like rx_samples_to_file.exe in the path "C:\Program Files (x86)\UHD\lib\uhd\examples". It says that
UHD Error:
Device discovery error: input stream error
--Detected Device:B210
--Operating over USB 2.
--Initialize CODEC contrl...
Is it normal with input stream error?
06-30-2016 10:56 AM
Hi leisurely,
I am not able to shed much light on this, but support@ettus.com will be able to provide you additional insight. I also recommend creating new forums for new questions. You will likely get more people to respond on a newer one. Good luck with your project!
John
06-30-2016 08:01 PM
Hi John,
Thanks for your kindly suggestions. I will have a try to find out if it matters with this error.
Leisurely
