VI Analyzer Enthusiasts Discussions
VIA Ignore doesn't work for Front Panel Property and Invoke Nodes test
Hey everyone,
I'm using LV 2018 SP1 f4 32-bit, and I'm seeing that the "#via_ignore Front Panel Property and Invoke Nodes" bookmark doesn't ignore these test failures, both when the bookmark is tied to a specific property/invoke node or globally to the entire VI.  Other tests are ignored correctly when using the appropriate #via_ignore bookmark.
The test itself is under the "Real-Time Module" parent item in the VI analyzer configuration, but VIs under a Windows target fail the test.  I'm not sure if it's even the intended behavior that RT-specific VI Analyzer tests are applied to non-RT VIs.
The attached VI demonstrates the problem if run through any VI Analyzer config that includes the Front Panel Property and Invoke Nodes test.
Is this a known issue or expected behavior?
Thanks!
David
(2,515 Views)
Accepted by topic author croohcifer
This is a known issue. The Real-Time VI Analyzer tests have not been updated to be UID-based tests...they are still shipped in the legacy RD format. Only UID-based tests can support #via_ignore bookmarks. More information on UID-based tests vs. RD-based tests is available in items #8 and #9 here.
(2,496 Views)
Got it.  Thanks, Darren!
(2,483 Views)
