I need a method to restore the EEPROM on a number of VXIpc-850.
VXIEDIT cannot change save changes to the EEPROM because it reports that it is corrupt. I have followed instructions in the User Manual on recovering the EEPROM using S9 and it does not resolve the problem.
I need to be able to set the MXI Bus timeout to disabled as the controller is used in a 3 chassis MXI-2 linked system. The default value of 125us does allow the MXI to work.
All these VXIpc-850 had worked in the past but for some reason the EEPROM in all but 1 has been corrupt.
Is there a low-level DOS utillity to re-flash the EEPROM?
