11-13-2018 02:25 PM
Can anyone direct me to or supply the Mictor pinout for this 783540-01 cable?
11-13-2018 02:48 PM
The easiest solution I could find was just to copy this over from my notes.
VirtualBench MICTOR Cable Pin Map
Daniel Larsen
Digital Hardware Engineer
11-14-2018 02:27 PM
Thanks for the reply SiMylo,
Can you confirm the pin numbering matches the TE Connectivity datasheet, odd numbered pins on one side evens on the other like this:
TE Mictor Drawing
I assumed this at first, but the organization of your table raised the question.
Thanks again.
SansPants
11-15-2018 08:15 AM
SansPants,
Yeah, I see that the chart would be cleaner if it had been organized with odd pins on one side and even pins on the other - that's just what I had in my notes. You are correct, the 'MICTOR PIN' column refers to the physical pin on that connector as shown.
Daniel Larsen
