VirtualBench
fgen initialization on external Trigger
For the NI_Virtual Bench with the external trigger BNC, Can we trigger the Function generator to start the square wave ? I mean, i want to produce the trigger so i have the start of the square wave
(7,366 Views)
Accepted by yeshwanth
You cannot trigger the function generator to start in response to an external signal.
However, you can export a signal that pulses when the FGEN starts to the external trigger BNC. You can do this with the "Dig Export Signal" entry point.
William Earle
NI R&D
(7,358 Views)
Example Please!I just need this function.
(7,305 Views)
You configure it through the Digital Instrument.  Here it is in the VirtualBench application:
Here it is in the LabVIEW API:
Zach Hindes
NI R&D
(7,283 Views)
Thanks ,will the fgen support external Trigger through Firmware update?
(7,096 Views)
No, there are no current plans for the function generator to support a start trigger.
Zach Hindes
NI R&D
(7,081 Views)
