Binned images are very useful for reducing processing time when you are looking at the entire image. It would be very useful to have a function that would perform binning on an image to generate a new image. The binning factor could be anywhere from 2x2 to 32x32 or even larger. I would be happy with powers of two, but any integer value would be even more useful. Different values for the X and Y binning would also be useful. The values could be simply added together and divided by a user specified divisor, much like the filter options. It would be similar to the existing IMAQ Block Statistics, but the output would be a new image ready for processing.
Right now, binning can be accomplished by multiple steps - filtering with the appropriate size filter, then using IMAQ Extract to reduce the size of the image. This is much slower and less efficient than a single binning function would be, since the filter must be applied to every pixel, instead of just the pixels you are keeping. It could be done in place on the original image if desired.
Bruce
Bruce Ammons
Ammons Engineering
