Vision Idea Exchange
Christian_Michelini
NI Vision Template Editor as Express VI
Status: New
'NI Vision Template Editor' is very helpful to create templates, but it would be better in a standalone Labview application to avoid calling an external exe (Editor) and browsing throught folders via Windows, allowing a final user (customer) to go around the O.S.
It would be appreciated to have the 'NI Vision Template Editor' available as an Express VI to use inside the standalone LV application.
Thanks.
C.M.
1 Comment
ChristopheC
As a workaround, you can call the Template Editor with a system exec using command line arguments. Check the Template Editor online help for information on how to do this.
