Using the image operators ADD or MAX or AVERAGE, even if both the images in the VI are calibrated, the output image is no longer calibrated.
To get around this, I have to separately copy the calibration to the output image. This is not possible from Vision Assistant (within VBAI) so I have to instead use a Run Labview VI step to re-calibrate the image. The same is also true for these VIs in Labview VDM, so I am posting this on both forums.
Chris Walker
Certified Labview Developer
