Vision Idea Exchange
Jeff_Spaulding
VBAI Threshold Step should work on ROI, not just "full image"
Status: Under Review
it would be handy if the VBAI "Threshold Image" step could operate on just a selected region of interest instead of only working on the full image.
3 Comments
varga.sm
The work around is a lot of steps if you need to programmically set a threshold.  This would also help speed up the inspection when using large images and needed to threshold only a small region.
Brad
Status changed to: New
This is a good idea. I'm reposting this as a Vision Development Module Idea since we would need this implemented in the Vision function before we could implement it in VBAI.
Brad
Status changed to: Under Review
