In Vision Assistant 2014 SP1, the "Create LabVIEW VI" function does not create a calibration file path in the generated code, for the Image Calibration function. Instead it reads in all of the calibration information and sets these to constants (or controls if selected it in the wizard) in the generated code. It would be good if this maintained a reference to the template.
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
https://wiredinsoftware.com.au
Since all calibration methods except simple calibration use a calibration file path as you suggested, I am marking this as complete since we don't plan to do this for the simple calibration case, but all others already do what you want.
