10-22-2021 04:08 AM
Dear Community,
I have been wasting hours trying to get an automated install of only the driver files/package working. I have been using the 21.0 offline iso from here (https://www.ni.com/de-at/support/downloads/drivers/download.ni-488-2.html#409630).
I tried tampering with the suite.dat file. /generatespecfile doesn't exist anymore apparently. --force-essentials, install ni-488.2. Nothing worked. 😕
Either the installer did not even show up, no error message, but still exit code 0. Also "unable to locate package ni-488.2 with a compatible version and architecture".
I tried calling the root Install.exe as well as bin/Install.exe with all possible arguments.
Please help me. I'd just need a command to install the GPIB drivers only. Thank you!
10-22-2021 10:10 AM - edited 10-22-2021 10:16 AM
Sorry that you had difficulty with the install! Yes, the installer technology has changed over the past few years to be Package Manger-based (NIPM), and the command-line options are different as well.
To automate the install of the offline installer:
That will install NIPM itself if necessary, and will take all of the defaults in the installer, including recommended packages. As a suggestion - you could use the "--passive" flag the first time to see what it's doing, then use the "--quiet" flag for production if you wanted a fully silent install.
Please post back if you're still having issues!
10-23-2021 06:10 AM
Thanks for the fast reply!
I guess I expressed myself not clear enough. The installation described in your steps already worked, but is not what we require.
Running the installer like that gives us:
As well as a ton of unnecessary services.
All we want is the driver for our GPIB adapter.
Thanks for trying to help. 🙂
10-25-2021 05:53 PM - edited 10-25-2021 06:01 PM
OK - some of those are recommended (optional) packages, but there currently isn't a command-line flag to the GUI installer to not install recommendations.
Here's a suggested workaround:
On step 5, that is just the driver runtime, with no LabVIEW or other ADE support. For that, you could instead install the "ni-488.2" package.
The CLI has decent built-in help, so you can do nipkg.exe help install to learn more about that command, for example to pass the "--yes and "--accept-eulas" flags to do the install unattended.
10-28-2021 09:12 AM
Thanks that finally worked!
Sadly this is super cumbersome to set up automated (e.g. via Ansible).
Is it possible to do that via the online installer in a more elegant way?
Needing only one iso/installer would help already.
Thanks once again. 🙂
