05-05-2015 07:26 AM
Hi all
I had a WSN 3230 and it have two DIO. Can i connect DS18B20 to DIO point?
Andy
05-05-2015 07:56 AM
Hi wcchung33a,
yes you can connect the DS18B20 to the 3230 node. just make sure the resolution of the ADC id enough to take the readings from the sensor as well as check whether the DIO's are general purpose DIO.
thanks
02-11-2017 09:53 AM
i want to find out the meaning of the code
if (cluster -1>=1) specially when they are trying to connect cluster members with the cluster head in a given cluster
