Wireless Sensor Networks
how to use temperature sensor LM35 on Node 3202?
Hey. I need help regarding making the VI i connected the temperature sensor Lm35 with Node 3202 , but when I made a VI it doesnot display any output on the thermometer in LABVIEW...
(4,894 Views)
Hi Faruu,
Can you provide some more information about the problem you are having? Any information about how you are interacting with the WSN-3202 (eg, what gateway are you using?), what your code is doing, and if you can read the values from the 3202 in NI Distributed System Manager or NI MAX would be helpful.
I would also recommend looking at our tutorial on Getting Started with NI Wireless Sensor Networks and the User Guide for the WSN-3202 to see if you are setting everything up correctly.
Charlie J.
(4,885 Views)
