NI myDAQ driver on MAX
How can I annex NI myDAQ driver? It is Not included in the list of drivers created when I installed NI-DAQmx. My operating system is Windows 7 Vista.
Thanks.
Diego.
(5,910 Views)
The NI-DAQmx driver installs support for the NI myDAQ to be used with the NI-DAQmx API in LabVIEW and provides support in MAX for creating DAQmx tasks/channels using the NI myDAQ. However, to get the NI ELVIS II/II+/myDAQ-specific express VIs and soft front panels, you will need to install the NI ELVISmx driver.
Donovan
(5,882 Views)
Hello diegote,
NI myDAQ Requires NI ELVISmx and NI DAQmx. You can check this link for additional information:
NI myDAQ Driver Download
https://www.ni.com/en/support/downloads/software-products/download.mydaq-software-suite.html
If you have any trouble this troubleshooting link coul help you:
NI myDAQ Troubleshooting Utility
https://forums.ni.com/t5/Example-Code/NI-myDAQ-Troubleshooting-Code/ta-p/4229669
Let us know if this information helped you. Kind regards.
David P.
Applications Engineer
www.ni.com/soporte
(5,846 Views)
